Re: M hard cranking
Posted by Bob M on November 14, 2000 at 15:45:20 from (172.154.134.118):
In Reply to: M hard cranking posted by Frank on November 14, 2000 at 15:26:23:
Frank - Most likely you've got bad (corroded or too small) battery cables. The tractor may also may be wired wrong if the wire between the ammeter and the starter switch heats up while cranking. Last possibility is the starter needs new brushes or a rebuilt.
If the tractor has the original or cheap replacement battery cables, suggest beginning by replacing both cables with new 1 gage or larger cables with new terminals and see if cranking speed improves.
Post A Followup
: Re: Re: M hard cranking
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
