Re: electrical issue on Farmall Cub 1951
Posted by old on April 09, 2013 at 14:57:46 from (209.86.226.57):
In Reply to: electrical issue on Farmall Cub 1951 posted by B Rankin on April 09, 2013 at 13:56:56:
Spark at that starter switch could well be a bad switch. The battery cable on that is insulated so if that insulation is going bad you could well get a spark at that as you call plunger
