Re: Starter for 1947 Farmall H
Posted by Dwight Wullweber on April 09, 2013 at 17:47:40 from (174.230.198.193):
In Reply to: Re: Starter for 1947 Farmall H posted by John M on April 09, 2013 at 14:26:05:
Thank you all for the suggestions and information. The starter had been working just fine until last fall when it would only click a little. Took it off and cleaned up the inside and used a jumper battery and worked fine. Installed and worked fine this spring for a couple of starts. But then, last week I started and ran for a few seconds and could not reach the choke and it died. Now we are back to the click when the starter switch is pressed. Same as last fall. The thought was the armature winding and when a certain spot is hit, it fails to engage the starter. BUT, you have a green horn here. Again, my car friend suggested a new starter. All comments would be appreciated.
