Re: International 485 stuck in low gear
Posted by Cyrush on April 10, 2013 at 07:10:54 from (109.156.55.12):
In Reply to: International 485 stuck in low gear posted by Juliaharrison on April 10, 2013 at 04:47:33:
You will probably need to lie under the l/hand side of the
tractor under the gear change and use a bar to lever the
external selectors back to the neutral position. Make sure the
engine is off !! And the handbrake is on. If the weight of the
tractor is on the transmissio it will be harder to do !!
They usually do this due to bent or worn linkages
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
