as the clutch disc wears you need to keep shortening the clutch rod to increase the free play. this is 3/4- 1" as per manual. so now you need to lengthen this rod to get the proper free play. this prevents the throw out brg. from continuously turning on the fingers. also an unadjusted clutch will cause slippage under load and burn the clutch disc and also cause heat cracks in pressure plate and flywheel. hopefully you have checked your's for wear and distortion. usually the flywheel gets resurfaced and pressure plate replaced. on these old putt's around tractors it may not be critical and will take some time to wear in with adjustment. leave pressure plate fingers alone.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
