Re: Model C float setting
Posted by gene bender on April 10, 2013 at 20:09:43 from (67.55.226.151):
In Reply to: Model C float setting posted by Kevin in Minnesota on April 10, 2013 at 16:49:06:
Some gently tap the needle to get a set so it will shut off. They can be a problem
