Re: Leak
Posted by pete 23 on April 11, 2013 at 10:16:37 from (74.47.40.242):
In Reply to: Leak posted by Ellis Kinney on April 11, 2013 at 06:18:26:
Yes it has a gasket and a o-ring or seal on the lever for pto disconnect. You need to drain that plug right behind plate at the very least. If tractor has a TA it should not be using gear lube, rather hy-tran to properly lubricate the TA over running clutch.
