Re: cub decal help
Posted by rustyfarmall on April 11, 2013 at 12:07:09 from (216.248.71.226):
In Reply to: cub decal help posted by steve Bontrager on April 11, 2013 at 10:14:07:
Borrow your wife's hairdryer. Apply a little heat to those decals and you should be able to straighten them out, or at least remove them with no damage to the paint.
I have no experience with the vinyl decals, but with the mylar type, spraying the surface with Windex will let you move those decals around and achieve the correct position BEFORE they are permanently attached.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
