With a delco 10si you have one wire that goes to the amp gauge which would be #10 If it is not - ground that would need changed. The there is the 2 wire plug on the alternator. It is marked #1 and #2. The #2 wire goes to the big stud which is also where the wire hooks going to the amp gauge. The #1 wire has the diode radio shack 276-1661 works well the sliver band to the alternator and then wire ran to the ignition side of coil and your done. You might be able to use the one wire from the generator if it goes to the amp gauge and as I said you have to be sure it is wired - ground
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
