Re: cub decal help
Posted by mkirsch on April 12, 2013 at 06:17:28 from (64.80.110.75):
In Reply to: cub decal help posted by steve Bontrager on April 11, 2013 at 10:14:07:
If you didn't wait for the paint to cure completely (30 days in 50+ degree weather for CaseIH 2150) before putting on the decals, you may be stuck repainting the hood. It will still be soft, and may peel away with the decals no matter how careful you are.
Don't go using one of those eraser things on new paint! Guaranteed you'll be doing a repaint.
Don't use a heat gun to soften the decals either. That'll definitely cause fresh paint to bubble up. Hair dryer should be ok.
No matter what you do it's going to be risky.
Catalyzed automotive paints should be nice and hard within a few hours so you'll have better luck.
Next time you go to apply the decal, spray some soapy water on the hood before positioning the decal. This will allow you to "float" it into place without it sticking down permanently. Then carefully squegee the water out from under the decal and let it dry.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
