Posted by gene bender on April 12, 2013 at 09:43:39 from (67.55.226.151):
In Reply to: Re: Magneto timing posted by teddy52food on April 12, 2013 at 07:24:27:
Do not move that gear but you will need to move the gear that drives the rotor when you replaced the points you probably got the rotor out of time with the cap. Make a mark with a marker where #1 wire goes to the plug. Then if you remove the cap and watch the rotor snap you will see the rotor move then stop at that tower when it fires. I am asuming that you didnt move the gear that drives the mag when you removed it as it does need to be lined up on the punch marks so it is in time with the valve trainect. Those marks are on the front and to see them you do need to remove the gov assy to check.From your description it sounds like the rotor is only off a tooth.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
