If you are jumping to the connection stud on the starter switch with a jump from an external battery, you are effectively eliminating the installed battery and the connections from it to the starter. Steps: Remove the nut and washers from the switch that hold the battery cable, and the wire to the amp meter. Clean this connection with 120 grit sand paper and reinstall. Try it.
Remove the battery terminals at the battery and clean them, then replace and tighten. Try it.
Check the voltage of the battery. If 6v it should be 6.3 volts or more.
If 12v it should be 12.6v
If less than that (either) it needs to be charged and retested. If still low the battery is probably bad.
Charging voltage is 7 volts to 7.2 volts on 6 volt systems. It is 14.2 to 14.6 volts on 12v systems. Start a new post, this one is getting old and far back in the pages. (I use the classic view) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
