If you get it running, no matter how poorly, the only reason it will shut off is lack of fuel or air. Static timing is 3 degrees btdc. It has a load advance on pump and you need a window on timing cover of pump to check that while running. Pretty hard to just tell you how to check it if you are not familiar with those pumps. Two problems that you might be having is, the fuel hose between filter and pump. They rot and collapse and let very little fuel to pump. Other problem is originally,(hard telling what an old beast like that has anymore) they have a ball check valve in the fuel return under fuel tank. It can get clogged or partially clogged and then engine will run a while and die. You can eleminate fuel return question completely by removing return line on top of pump and see if it will keep running that way.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
