When you say the the engine slows down and stops when it gets warmed up, It is possible that the plastic ring inside the injection pump that holdes the governor weight retainer together may be falling apart pluging up the return circuit. As the engine is running the pressure builds up inside the injection pump and prevents the pumping plungers from moving out as far as needed to get a new charge of fuel. A simple test is to loosen up the small timing window, on the side of the injection pump, as the engine is slowing down, allow some fuel to escape. If the engine speeds up you found the problem. You only need a screwdriver to preform this test. Let us know what you find. Good Luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
