Re: steering gear box
Posted by Haas on November 15, 2000 at 06:35:36 from (129.37.117.41):
In Reply to: steering gear box posted by joe on November 14, 2000 at 17:50:07:
That nut holds in the worm gear and the worm gear thrust bearing. If you have no other leaks on the steering gear seals, you are lucky. The nut is just pipe threads. Use some plumbers pipe dope on the threads. RectorSeal 5 is good. You can get it at any home center, such as Home Depot. The only advantage of Teflon tape is that it is not messy. The RectorSeal 5 is a Teflon emulsion. Of course when you remove the nut, all the oil will run out of the steering gear. Another thing. Many folks just use grease in the steering gears on these older tractors because it is so hard to stop all the leaks.
Post A Followup
: Re: Re: steering gear box
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
