Re: Torque Amplifier
Posted by Zachary Hoyt on April 14, 2013 at 10:06:50 from (184.10.220.56):
In Reply to: Torque Amplifier posted by Ellis Kinney on April 14, 2013 at 09:07:02:
Not recalling what tractor you have I can only say what I have found on my 300 row crop. That plate can be unbolted and removed ande you can make a new gasket out of some gasket paper from the hardware store. I used a hole punch to make the bolt holes in my gasket and scissors to cut it out. The seasonal disconnect is the only difficult part and all you have to do is to make sure that the knob on the inside arm of the disconnect lever goes back in the groove in the collar. If you don't want to use the seasonal disconnect you can buy a split collar from Surplus Center and lock the two disconnect collars together. The TA needs hytran as 80 wt is not sufficient to keep it lubricated. The TA is a common reservoir with the transmission and rear end.
Zach
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
