Re: Steering box for 1953 A
Posted by Haas on November 15, 2000 at 06:48:01 from (129.37.117.41):
In Reply to: Steering box for 1953 A posted by Paul Shuler on November 14, 2000 at 14:08:41:
If the tractor is a 1953, it has to be a Super A. The way to tell is the Super A has a hydraulic system, the A does not. Replacing the bearings in the steering gear will likely make a lot of difference in the steering play. Also, sometimes the nut under the steering gear that holds on the steering arm that goes to the tie rods gets loose. If that nut is loose, you will have a lot of play.
Post A Followup
: Re: Re: Steering box for 1953 A
