Posted by John T on April 14, 2013 at 20:08:23 from (216.249.82.117):
In Reply to: farmall c generator posted by burnsg2003 on April 14, 2013 at 18:16:27:
I agree with my sparky buddies, check the belt and its tension,,,,,,,Polarize once more just to be safe,,,,,,Insure the genny has a good frame ground (maybe run a ground jumper from gennys case to batterys grounded post),,,,,Try dead grounding the gennys FLD post at fast RPM n see if she charges then??? If so but NOT otherwise, the VR may not be well grounded or is bad or mis adjusted or the wires bad from FLD on genny to FLD on VR.....
Sounds like you already tried my troubleshooting procedure right?? Its Para 5 shows how to tell if non charging is a Genny versus a VR problem and has a Motor Test for the genny itself
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
