Re: 300/350 Utility: Anyone using 15 inch front tires? What t...
Posted by IAtractorKid on April 15, 2013 at 08:57:14 from (184.97.40.2):
In Reply to: 300/350 Utility: Anyone using 15 inch front tires? What t... posted by Kerwin on April 15, 2013 at 08:39:51:
I have a Farmall 400 row crop with a loader and wide front end and am using a standard 6-bolt 15" implement rim with tri-rib 7.50-15 8-ply tires. At least 1" of clearance between axle and tire. If I come across a set of wider rims, I'll be going up to 9.5L-15 implement tires.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
