Re: 300/350 Utility: Anyone using 15 inch front tires? What
Posted by AG in IN on April 15, 2013 at 09:07:06 from (67.237.16.65):
In Reply to: 300/350 Utility: Anyone using 15 inch front tires? What t... posted by Kerwin on April 15, 2013 at 08:39:51:
A 6 bolt rim with the center spacing you need can most likely still be had from any decent tire shop, be it a 15 or 16 inch rim and should be available in a variety of widths. Just watch your spindle clearances (and overall width if you have a narrow bucket on the loader if you don't want to run down what you're pushing/loading). Watch where everything ends up when you're making a full turn either way, too. Stuff might rub that didn't before.
My 460U had 7.60-15 tires on it when I bought it. Only reason I changed them to 7.50-16 is the 7.60-15's were rib implement tires, and I had the 16" rims and new 4-rib fronts in the corner of the shed.
There should be many options in tire and rim sizes available in both 15 and 16 inch that will get the height and width you want for the front of that tractor. Some low-profile sizes are available for front tractor tires, too.
AG
