Re: SM transmission input shaft seal.
Posted by gab on April 15, 2013 at 16:57:04 from (50.103.31.245):
In Reply to: SM transmission input shaft seal. posted by 47 Bill on April 15, 2013 at 06:34:51:
It isn't bad coming apart but it took every bit of patience I could find to get it back together. Get the clutch release shaft out through the side of the bell housing, the bolts out of the aluminum t.o. bearing carrier, every other bolt out of the press. plate and install in the plate cover to collapse the 3 fingers. Now the shaft will come out, you can get the disc out too if you want but the pressure plate won't come out the bottom.
Back up a couple lines and remove the last 3 press. plate bolts.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
