Re: Bolt-on top link connector
Posted by Russ from MN on April 15, 2013 at 17:16:34 from (68.235.89.3):
In Reply to: Bolt-on top link connector posted by freefour on April 15, 2013 at 08:43:59:
I think you could wrap a piece of plate around the
cross shaft and clamp it with a bolt close, then
have another hole a little farther out for the top
link. That end of the top link could be turned 90
degrees as the shaft rotates anyhow. Before I
retired I could've made one easily with the shop
equipment I had access to.
