Any "slop" in the entire throttle control assembly (govenor bushings, throttle linkage, throttle shaft, etc) will cause errant behavior in throttle response. Add in weak springs, and results are unpredictable.
Check each bushing point for wear and slop. repair/replace accordingly. The weights themselves will also have a certain amount of influence on throttle response if the pivot holes are worn.
Like any relatively close tolerance application, when worn, it does nto perform as it should.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
