Re: 1066 altenator
Posted by Jon Hagen on April 16, 2013 at 23:07:22 from (69.26.17.61):
In Reply to: Re: 1066 altenator posted by Bob M on April 16, 2013 at 12:03:40:
Bob M.
When rebuilding my 856, I converted from the stock external regulator 10DN and substituted internal regulator 10SI alternator.
I made a jumper wire with a male blade connector on each end. The wire needs to be long enough to plug into the outermost terminal at each end of the regulator plug.(in the compartment down by your feet, remove the external regulator) This will connect the charge light to the field wire. Buy a SI series harness repair plug from an auto parts store to fit the 10SI alternator. Put a ring terminal on the #2 (red)sense wire and connect it to the Big "bat" stud on the alt rear. Splice the field wire in the harness to the #1(white) excite wire on the 10SI alternator plug. Tape up the "R" wire in the harness as it is no longer used.
Connect the heavy harness Bat wire to the alternator BAT stud.
The tractor is now wired for a working charge light with the internal regulated 10SI alternator.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
