Posted by Bill in IL on April 17, 2013 at 05:46:10 from (132.3.49.80):
In Reply to: 560 valve oiling posted by Bill in IL on April 16, 2013 at 17:59:35:
I checked things over quickly this morning. Yes there are expansion plugs in the end of the tube. I forgot that the last rocker arm support at number 6 cylinder is fixed to the tube and yes it is plugged. I can see it on the parts breakdown now too. The oil is leaking from between the rocker arm and the support shaft (bushings) on the side between the intake and exhaust rocker for number 6 cylinder. It was running from the other rockers too number 6 just had the most.
In other words it seems to support my theory that the bushings are wore and may need some attention. I remember while cleaning them they did show wear enough that the base metal of the bushing was showing through.
Can these rockers be rebuilt with new bushings? How else can this be repaired? They are listed at IH for $113 each times 12 so thats not an option. Going to do some checking for used ones.
Also while starting it this morning it started good but still got one puff back up the intake. That's going to be another problem that still needs attention. I have set the timing by the book with it at 2 deg BTDC till I had spark at the points. What else could be causing this? I don't think its sticking valves anymore cause I was oiling them with and oil can last night to supplement what was not coming from the rockers.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
