Re: Pictures and M&W hydraulic pump for Super H
Posted by mkirsch on April 17, 2013 at 05:59:33 from (64.80.110.75):
In Reply to: Pictures and M&W hydraulic pump for Super H posted by Dean (West MI) on April 16, 2013 at 06:01:50:
The IH pump fits the Super H with no modifications necessary, and you can use your stock distributor.
Is there a specific reason you want the M&W setup?
The IH is certainly more expensive than a used M&W should be, but you can get one RIGHT NOW. If you need it for spring planting, that may be a consideration.
It's not like you can snap your fingers and make whatever obscure accessory appear out of thin air... Though, if you can, we need to talk...
Of course if you're building an M&W tractor, or you want one because your Dad's/Grandfather's/Uncle's tractor had one... Best of luck to you.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
