Re: Pictures and M&W hydraulic pump for Super H
Posted by sflem849 on April 17, 2013 at 07:42:10 from (69.197.84.39):
In Reply to: Pictures and M&W hydraulic pump for Super H posted by Dean (West MI) on April 16, 2013 at 06:01:50:
The M&W ones would go on all tractors, but the IH ones were only supposed to go on the SH. IIRC that is because they had a beefier timing gear cover and a differernt timing gear.
You are talking about a live hyd pump. They were made by both M&W and IH at that point in time.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
