Farmall Tractors Discussion Board
Re: MOST UNUSUAL IH TRACTOR EVER SEEN, PART TWO
Posted by jeff on January 16, 1999 at 16:55:50:
In Reply to: MOST UNUSUAL IH TRACTOR EVER SEEN, PART TWO posted by Harold H on January 16, 1999 at 07:33:43:
I saw an F-12 with a car/pick-up rear end mounted behind the tractor. A driveshaft ran from the pto to the rear wheels. The tractor could then be put into neutral with the pto engaged so as to increase the "roadgear" speed.
Post a Followup
: Re: Re: MOST UNUSUAL IH TRACTOR EVER SEEN, PART TWO
