Posted by sgtb on April 17, 2013 at 10:14:21 from (163.191.228.254):
In Reply to: H charging system posted by peanuthil12 on April 17, 2013 at 08:47:04:
If you have a one wire alternator, the wire simply goes to the ammeter. Off of the same post, a wire will go to your ignition switch and to your light switch, (hopefully through a fuse) The other ammeter post should have a wire leading to either the bsttery directly, or more likely, to the post on the starte which is connected to the battery. If it shows discharge on the ammeter in that configuration, swap the wires from post to post on the ammeter. If it still won't charge, pull the alternator and take it to a shop to be tested.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
