Re: 560 valve oiling
Posted by Owen Aaland on April 17, 2013 at 10:32:21 from (216.47.35.225):
In Reply to: 560 valve oiling posted by Bill in IL on April 16, 2013 at 17:59:35:
Oil to the cylinder head flows through a hole drilled in a camshaft journal. The hole is offset in the journal so that it lines up with the holes in the bearing only once a revolution. The crankshaft has to make two turns to get one spurt of oil to the rockers.
Oil oozing out of the rockers and flowing down to the valve ends is about as good as you are going to get. With all the problems caused to too much oil to the valve stems I wouldn't be looking to get any more to oil them.
