Posted by pete 23 on April 17, 2013 at 11:11:44 from (74.47.40.242):
In Reply to: 986 international posted by tas986 on April 16, 2013 at 16:32:23:
Hour meters on a knob digital tach are powered through a oil sending unit on engine, no oil pressure, no hour reading unless switch sticks which they do. The touch panel data center reads hours off tachometer sending unit with flywheel turning. Reads by time regardless of rpm. Some of them would malfunction and read no hours for a while and then the little wheels would take off like crazy and run up a bunch of hours. Saw that a few times when they were new. Really zips but usually only runs up maybe 10 or 20 hours on the ones I came across.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
