I don't know the cause of the alternator test stand going POP but I will say this. More than one time, when the stator windings were shorted out in an alternator, you would be amazed about how much power it took to turn that in the test stand. It would stall our machine right out and I tested many 100 amp alternators at full 100 amp output at recommended 13 volts test. It made the stand work hard but not nearly as hard as the bad alternator which was not even coming close to heavy output. Ones that tested way high on voltage didn't require much power to turn as long as you wern't loading it down with heavy amperage at the same time.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
