No, a IH or M&W pump for a H, SH, 300 or 350 that mounts to the engine front cover or plate with a drive gear on the pump shaft won't work on the AC. M&W 1PX pump mounts to the ignition drive housing like used on a H or SH without a pump mounted to the front cover plate. 1PX bolts to the ignition drive of several tractors. On the B if the distributor and right angle drive is removed at the 2 bolt mounting flange( I think the B has a standard ignition drive flange) a 1PX pump and M&W type distributor drive used with that pump would bolt in its place if the housing clears everything. I have no idea if the B drive parts to the ignition unit is strong enough to handle the hydraulic load. Also don't know if the B rotation is the same.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
