Re: changing super c to 12 volt.
Posted by CNKS on April 17, 2013 at 18:13:26 from (216.144.104.128):
In Reply to: changing super c to 12 volt. posted by truckerlary on April 17, 2013 at 16:58:57:
The ONLY reason to convert a C to 12 volts is that you can use an alternator, if you are tired of messing with generators. That tractor is one of the easiest starting 6 volt tractors there is. Related to your question, as far as I know you will not be successful using a 12 volt battery and a 6 volt generator, others may answer your question.
