Re: Pictures and M&W hydraulic pump for Super H
Posted by mkirsch on April 18, 2013 at 05:14:34 from (64.80.110.74):
In Reply to: Pictures and M&W hydraulic pump for Super H posted by Dean (West MI) on April 16, 2013 at 06:01:50:
Yeah, the IH pump won't work on the Allis.
It mounts directly to the front cover of the engine, not the ignition drive like the M&W. The IH pump REPLACES the ignition drive, in fact.
You could mount an M&W pump to an IH pump and have yourself a real conglomeration, though. Probably tear the cam shaft out if you tried to use it, but it would look cool.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
