Well, you're almost to the bottom of page 1 on the modern view with no answers, so I'll give you a bump. Maybe someone can come along with more helpful info.
So you shift into low, it goes into low, then shifts back into high spontaneously? Does it shift under any particular conditions, like it won't stay in low under a heavy load or something?
All there is to shifting that TA is a simple clutch. If the clutch is released it's in low/TA. If the clutch is engaged, it's in high/direct.
So for some reason, the TA clutch is grabbing even though the lever is in low. Could be a simple adjustment, or it could be that your TA throwout bearing is going bad? Just a guess.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
