44 A Rear Wheels Question
Posted by Roger A. Mueller on November 15, 2000 at 17:22:52 from (209.150.73.61):
-As sitting in the tractor-........My left rear wheel center hub is approximately 3/4 inches with four supports riveted to the center part of the rim to hold it........Which I believe to be correct.
My right rear wheel center is approximately 1/8 inches thick with four supports riveted to the edge of the rim and the rim is about 1 inch shorter in width then the left side.
Are the rims suppose to be the same size in width?
Are the center hubs suppose to be the same thickness?
Is it possible that my right hub thickness is only 1/8 inch because of Counter Balance factor?
Any help would be appreciated.......I am concerned that I might have a wrong right rim and hub........Thanks......Roger
Post A Followup
: Re: 44 A Rear Wheels Question
