Re: resistor
Posted by Janicholson on April 18, 2013 at 20:35:46 from (74.60.94.18):
In Reply to: resistor posted by blunted on April 18, 2013 at 19:25:49:
(assuming it is the ballast resistor) A shorted resistor (to ground when the ignition is on) will burn out. The resistor on the lights will also smoke and burn out if shorted.
The Resistor used on the charging system (when no regulator is used) can also burn up. But it needs to be connected to a hot wire as it is grounded normally. Jim
