Posted by John T on April 19, 2013 at 04:43:35 from (216.249.82.117):
In Reply to: resistor posted by blunted on April 18, 2013 at 19:25:49:
"i think i shorted out the resistor. can that happen"
Yes that CAN HAPPEN
Know what resistor you shorted?? Ignition Ballast Resistor (stand alone device somewhere between IGn switch and coil) or Light Dimming resistor (located on back of light switch)??
Did it short across itself i.e. became by passed orrrrrrrr did one end get shorted to frame ground???
Ifffffff you shorted across an Ignition Ballast she will run but the coil will get very hotttttttt and could eventually burn up and the also the points get burned,,,,,,,,,Iffffff the input (from Ign switch) of the Ballast got shorted to frame a wire would melt or a fuze would get blown,,,,,,,,Iffffffff the output (to coil) of the ballast got shorted to frame she wouldnt run and possibly some smoke due to an overheated ballast..
So yes it can happen and the consequences depends on which resistor was shorted,,,,,, and on which end,,,,,,,,,,,and to where
Their job is to drop voltage (say 12 to 6) and limit current to the downstream LOAD, be that an ignition coil (like a 6 votl coil on a 12 volt tractor) or the lighting circuit for DIM operation.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
