Re: Too much?
Posted by mkirsch on April 19, 2013 at 07:03:55 from (64.80.110.74):
In Reply to: Too much? posted by Dave H (MI) on April 18, 2013 at 06:50:34:
The key to adding separate remotes for the loader is to either:
1. Redirect the oil going IN to the factory valve stack to the loader's controls, then back to the valve stack.
OR
2. Redirect the oil coming OUT of the factory valve stack to the loader's controls, then back into the tractor's reservoir.
I know it's possible on a 300U, but I don't know how it's done.
The pump should be 12GPM and 1250PSI. That's adequate for a loader
Does the tractor have good tight powerful power steering?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
