Re: resistor
Posted by John T on April 19, 2013 at 07:34:47 from (216.249.82.117):
In Reply to: Re: resistor posted by mkirsch on April 19, 2013 at 06:27:13:
I have observed ballast resistors in the 1.2 ohms range all the way up to over 2 so it can indeed make a difference. Ideally they should be matched to the coil so theres a 50 50 voltage divider with 6 volts dropped across BOTH the ballast and a 6 volt rated coil. Unless theres a need for the 6/12 ballast by pass system for improved cold weather starting I agree go with a 12 volt coil no dern ballast required
John T
