Re: Farmall Super A Steering Improvement
Posted by Roger on November 15, 2000 at 19:58:17 from (209.100.170.137):
In Reply to: Farmall Super A Steering Improvement posted by John on November 15, 2000 at 12:36:57:
John,
On my A the steering arm that attaches to the output shaft of the steering assy was loose. I tightened it up and that took most of the looseness out. I also replaced the bearings inside the steering assy. That also made a big difference. Unless it was run without grease, the gears may not be too bad. I also priced the gears and I could have bought another A cheaper. I have not checked with a gear cutting company to see if they could rebuild the gears reasonable, as I was at a gear cutting company recently and saw them rebuilding gears for equipment. Roger
Post A Followup
: Re: Re: Farmall Super A Steering Improvement
