Re: 62' 460 Clutch TA Linkage Adjustment
Posted by pete 23 on April 19, 2013 at 09:21:22 from (74.47.40.242):
In Reply to: 62' 460 Clutch TA Linkage Adjustment posted by Gavin Ahlbrecht63560D on April 18, 2013 at 19:46:11:
Am I reading this correct. You cannot get the tractor in gear. That means the clutch is not releasing, just the opposite of engaging. If you have approx 1 1/4 inch of free movement of clutch pedal from platform to the point where throwout bearing makes contact with clutch fingers, and you cannot get it in gear,(grinds gears with engine running) the you have a problem right at the clutch and not the external linkages. Disk in backwards, throwout bearing cocked on sleeve, fingers (maybe only one out of wack) damaged pressure plate when putting together or a host of other causes. Hard to tell from here.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
