I see WOpp has already offered you one, but I will chime in with a bit of help too.
I took one out of my Super WD-9 that had 3 cogs cracked and years ago my neighbour broke all of the cogs off of his WD-9 snow plow tractor and he thought that the hard push of plow caused it to break the cogs--he is probably right.
I think you would be okay with your show tractor with the shaft you have but if you are like me, you will probably want to fix it right.
A clutch shaft out of a W-9 or WD-9 might also fit but I am not sure. The part numbers are slightly different between those and a 650:
W-9/WD-9 is 58610DA
600/650 is 58610DB
The last digit is the only difference in part numbers which might mean that there was some minor improvement made to the original part (Ford auto parts work that way--I am not sure about IHC). Regardless, a W-9/WD-9 clutch shaft would be easier to find and might be in better shape since they weren't subjected to as much horsepower.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
