Posted by Bob M on April 19, 2013 at 17:06:54 from (67.240.171.136):
In Reply to: Farmall 806 wiring posted by Mark Nafziger on April 19, 2013 at 13:33:51:
Mark - The alternator light will not work with a 1-wire alternator. (The purpose of one of the auxiliary wires on a 3-wire alternator is control the warning light). So if you want to keep an eye on the electrical system best to install a voltmeter in the dash.
The oil light should be straightforward. The circuit runs from a switched pole on the ignition switch (IGN or ACC) to the dash light then to the pressure switch.
To test, with the ignition "on" ground the terminal at the pressure switch. If the oil light comes on the pressure switch is bad. But if the light stays dark, problem is in the wiring or the dash lamp itself.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
