SMTA with fast hitch
Posted by Ted W on April 19, 2013 at 20:10:07 from (75.208.236.208):
I am working on a SMTA that has a fast hitch from a 450 era tractor (based upon the hitch casting numbers). I have a Ford 961 that I use with the following 3 point pieces of equipment; JD Model 80 blade, Gearmore 6 ft disc, Ford 3 bottom plow and a JD flail mower. After reading numerous comments on this forum I assume there is not a good conversion to 3 point utilizing the fast hitch, is this correct? I assume, I need to be looking for a used Saginau or Worksaver 3 point. Any thoughts or direction to consider appreciated. The Ford is easy to use with the 3 point implements and my goal is to use
the SMTA in a similar fashion.
