Re: Farmall 560 diesel
Posted by CNKS on April 20, 2013 at 08:59:25 from (216.144.104.128):
In Reply to: Farmall 560 diesel posted by big fat herb on April 20, 2013 at 08:20:12:
In excess of 6000 lbs depending on how it is equipped. Easy to exceed 7000 with loaded tires and wheel weights.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
