Re: Reworking a m head for a super m
Posted by D Slater on April 20, 2013 at 16:50:10 from (184.15.34.63):
In Reply to: Reworking a m head for a super m posted by shawnm on April 20, 2013 at 13:21:23:
M and SM gasoline heads use the same valve numbers. Maybe a small power loss with some M gasoline heads compared to a super. Probably couldn't feel it on most tractors. Really need to know the head number removed and the one being installed. Late M and SM tractors used gasoline heads 8060 DC or 8574 DB. Lower suffix letters came on most M tractors. But lots of heads were replaced over the years. So you can find 8060 DC and 8574 DB on some M tractors now. Can also find 8060 DD and 8574 DC the replacement for previous heads on M and SM tractors.
My be just my luck that I seem to find less 8574 DC heads cracked than the others.
There was also a newer replacement head number that shows up rarely.
You could also use 400 and 450 heads if wanted or found.
