Posted by tractorboy 27 on April 21, 2013 at 08:33:08 from (75.156.113.67):
In Reply to: HELP! posted by Pavel on April 20, 2013 at 11:56:34:
you have to remove the gas tank, belt pully, starter, linkage rods,disconnect guages, etc and the cover will come off without splitting the tractor in two. you cant split the tractor in two without doing the previous as the bolts that hold the two halves together are inside the body. Have you removed the inspection plate from the bottom of the tractor and taken a look inside to see what is the problem. I had a mouse nest and wasp nest inside mine that was preventing movement of the fingers on the pressure plate
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
