Posted by jimb2 on April 21, 2013 at 12:33:03 from (99.241.76.141):
In Reply to: IH 454 hydrolics posted by Mel in OR on April 21, 2013 at 11:49:24:
Hi Mel, the 454 Diesel could be assembled in USA but D-179 Diesel engine was made in Neuss Germany, main frame axles/trans/diff/torque tube were made in Doncaster UK.
Re 3pt leaking down could be lift cylinder or 3pt lift control valve leaking. Problem is only a nuisance, must remember to lower 3pt implement before shutting engine off, sometimes hydraulic will jerk up if really bad leak. My brother has 454 that has 3pt leak down for at least 25 years now with no other problems.
The big problems with those models of tractors is the Operator forgets to release the parking brake and drives tractor with parking brake engaged and the parking brake band gets chewed up in the transmission. The bits of chewed up brake band ends up clogging up hydraulic filter and other small hydraulic orifices. Later models have a flashing park brake engaged lamp on the dash.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
